bigchunkytaco
Thread starter- Joined
- Feb 6, 2011
- 54
hi all,
i got running an 80s model evinrude model #50303R serial #89943, have run it around a fair bit for 20 mins at a time however i am unsure if its pumping water. there are 2 slits on the back of the upper leg that appear to be exhaust ports however i dont think there is water coming from here. is there supposed to be a telltale? the engine sits pretty low in the water on this particular boat so am hoping there is another exit port for circulating water that i am not seeing. i think the heat alarm is disconnected so better safe than sorry any help much appreciated, also if anyone has a similar model do they know which wire should go to that choke/primer looking solenoid.. thanks in advance!
