Evinrude 48 spl starts intermittently
BT1280
Hey Guys. First time. I have a 1994 Evinrude 48 spl. This has been a great motor in the two years I have had her. Last year I replaced the power pack, charge coil, plugs, cleaned, and rebuilt carbs, as well as disassembled and cleaned controls, etc. Motor was running great until a couple days ago. I have had it out in the bay as well as a couple lake trips with not even a hiccup. She always starts on the first key turn and never gives me one issue. Then when I was fishing the other day, I went to turn her on and go to a different spot and it would just crank and not start. Good battery, good starter speed, just wouldn’t start. Next day, started right up. No issues. Idles and runs perfect. Then the very next day it was doing the same thing of turning but not starting. Good fuel, primer solenoid tested and passed, good spark on both plugs and replaced plugs just in case. Tested the stop safety circuit, neutral, forward, and reverse circuit from the engine wiring harness back to the control and it all passed.
This is one has me baffled, because it has good fuel and spark when it is doing this. Then today I hit the key two times in a row and it started and ran fine all day. Turned it off multiple times to try to duplicate problem and it wouldn’t do it. Thoughts? If this was a timing issue, I don’t think it would run perfect the rest of the time, right?
Thanks
juno pierrat
Maybe look under flywheel to see if charge coil or ignition sensor has dark goo leaking from one of them. At same time check flywheel key for damage. start switch ?
Crosbyman
can you check for sparks when it cranks but does not fire ...
power pack on my old Merc Classic had the same symptoms....drove me nuts
BT1280
Plan on pulling the flywheel this weekend and looking. I replaced the charge coil and power pack last season so “”hopefully” it’s nkt one of those. I’ll pull the flywheel after I get off shift and advise. Thanks guys.
BT1280
To be more specific, when it’s cranking only, and not starting I am able to check for spark and DO have good spark. I leave one plug installed, and ground the other plug to see spark. Then reverse process and check other plug. Have good spark every time I check. Good due as well. I am not very experienced with timing, but if it has good spark and fuel, wondering if it might be a timing issue. I’ll post findings under flywheel after I get off shift.
Honorary Supreme Mariner
Does spark jump a gap of 7/16" or more , yes or no.-----Timing on these motors does not change !-----Well , except for the sheared flywheel key.-----Do you push the key in while cranking , yes or no ?
BT1280
I haven’t measured the gap of spark up to 7/16”. I have only put the plug to the block and watched each plug have a strong spark, but have not measured it.
I DO push the key in every time to prime it while starting. YES.
Thank you you for your patience as y’all are helping me out. Keep them coming. Thanks.
You can not measure " strong spark " with a sparkplug.----Do the real test.
oldboat1
If the motor was running well before you replaced the power pack and charge coil (?), I would first pull the flywheel and see if it moved on the shaft (affects the timing) — indicator is usually a sheared or partially sheared key, as suggested. You may not have torqued the flywheel down tightly enough when doing the earlier work. Also, get an adjustable spark tester to properly check spark ($10 at an auto parts store).
You might go back to the original power pack and charge coil, depending on whether there were issues before replacing them. A new component might be defective — either that or assembly was an issue (pinched wires/abrasions, or corrosion in an amphenol connector, maybe charge coil not mounted securely).
Crosbyman
is that a push in choke when you turn the key and push .... (sorry to ask) if it is a choke function can you hear the choke selenoid pulling and closing the plate
can you have somebody ... just push it ON and look at the choke plate
update: looks like it is a PRIMER selenoid .... same question.... does it work ....can you see/hear it pull up ???i
can it fire up if you squirt some fuel in the carb ??
BT1280
It is a primer solenoid. You can hear the click and I have disconnected both lines from each carb and it DOES squirt out fuel when you push the primer button on the ignition.
BT1280
No. Haven’t checked compression. I’ve been meaning to just out of curiosity. I put that to the back of the list because I didn’t think that would cause the issue. I could definitely be wrong though. That’s why I’m on here having you guys drop some knowledge on me. Ha I’ve been meaning to do JT for some time.
And the thing that baffles me is when it decides to start right up, it runs like new. Doesn’t nock, isles perfect, revs perfect, etc.
BT1280
Just on a side note, I wanted to confirm something. On my 48 spl under the flywheel, I have a charge coil, power pack, and stator. I know the charge coil creates the magnetic charge, sends it to the power pack which in turns amplified the charge and sends it to the ignition coil which does the same before sending the charge to the plugs. I simplified this part for times sake.
My question is what exactly does my stator do? Does it also supply some of the voltage to the ignition system or is it solely for recharging my battery?
The stator sends a voltage pulse to the capacitor in the powerpack.----Switches directed by the sensor coil send the pulse to the coil where it is AMPLIFIED to jump the gap in the sparkplug.----Stator also supplies voltage to charge the battery.
BT1280
So aside from the stator sending voltage to charge the battery, how does it differ from the charge coil. I know the charge coil sends voltage to the power pack—ignition coil— then to plugs. Does the stator just supplement this voltage?
I know now that in the 48 it is a little different because my marine shop was dead set on the charge coil being the one that recharged the battery and the stator sending voltage, until I brought schematics in there and sat down with them. Haha
so...under my flywheel I have the charge coil, stator, and power pack. Oh, and also. Thank you racerone for getting back to my questions so quick. You’ve been a huge help.
The stator has 2 SEPERATE systems / circuits.-------One charges the battery through the rectifier.---Other one ( aka charge coil ) provides the pulse for ignition.-----It has been proven to me time and time again that volts / amps / ohms are confusing to folks because you can not see them.
BT1280
You mentioned sensor coil. Would you be referring to the charge coil? Not trying to be difficult, but I have learned quickly that people have many names for the same components in the ignition system and just want to make sure I’m tracking. Ie: ignition module and power pack as well as, the charge coil is actually coil and lam assembly.
Here is is a better look at what I have. I really enjoy the conversation. You guys are much appreciated. I’ve been a gear head in the past while a helicopter flight mechanic in the Coast Guard, been a paramedic for 15 years now and having to brush back up on my electrical knowledge. Lol.
BT1280
[No message]
BT1280
I think I see where the confusion has been when trying to explain this setup to the shop as well as other knowledgeable mechanics. My charge coil is seperate from the “stator”. My stator is the three pronged component with the two red windings, then my charge coil(black goo was before replacement last year), and my power pack.
I have found in discussion that it is common for people to mention the stator supplies the voltage, but that is only because a lot of “stators” are actually the charge coil and stator in one. Am I getting warm racerone? I understand voltage, amperage, and ohms( on a basic level). Still learning though. Nowadays I spend my time giving meds on an ambulance and not turning wrenches for a living.
Racerone, is this what you do for a living or just a hobby?
