Evinrude 40hp
francoism
I'm considering to buy a small outboard with a '72 Evinrude 40hp motor. The seller does not have more information (the boat is currently stored) like the exact model number of the motor.<br /><br />Being a newbie with boat motors, what are some of the obvious things I should check as I inspect the motor?<br /><br />Thanks for any pointers.<br /> :confused:
tscott
Re: Evinrude 40hp
Have the seller put it on rabbit ears and start it for you.Make sure the water pump works and it runs before you talk about a price.Make sure it doesn't leak oil from lower unit as well.
D
DJ
Guest
Re: Evinrude 40hp
amfm,<br /><br />The '72's were electric shift.<br /><br />If you do not know a lot about outboards, I would avoid it.
Lark40
Re: Evinrude 40hp
They also came with manual shift. I have two new 1974 40 hp LU's with the shift rods.
