Evinrude 40 HP WorkTwin Question
Find ----evinrudeparts.ca-----Look up the parts there.----Or-----crowley marine----for parts there.
  • Like
Reactions: F_R
F_R
I believe you have a motor slightly older than 1984. Why? because it has the beloved Lo-Tension magneto. You need to know this if you are going to order a coil.
EDIT: 1983 model E40RWLCTA has the Lo-Tension magneto. Coil for that one is part number 0502881
That ignition system is shown on the 83 commercial models.-----Note----COMMERCIAL----Is all about marketing.
24simpson
Compression results. 90 on the top cylinder and 64 on the bottom. Hasn't ran in forever so the rings may be stuck some.
Do not spend any beer tokens at this time.-----Remove bypass covers and have a look at pistons / rings.----This does not sound encouraging.
24simpson
Do the Rings have any tension?
I didn't take the covers off yet. I bore scoped it. The motor is outside on the boat still, I am waiting for help to get it on a stand and into the garage before tearing it open.
24simpson
I cannot find model E40RWLCTA anywhere online. :-(
Well----I can find that 40 listed for 1983.----But not the A model.------The A means nothing as far as parts are concerned.-----Not sure why you are confused by this.----They just did not sell many of these and only in certain markets.-----Your local friendly dealer ( if you still have one ) can help you with this.
24simpson
I didn't know that the last character didn't matter. New to this boat motor thing. Thanks for the help.
