Evinrude 4 hp won't pull gas from tank
Richard Anator
My Evinrude 4 hp model 4736 runs good but I have to squeeze the fuel bulb constantly to keep her going. The fuel line and the tank are new and the connections look tight. Any clues will be appriciated.
CATransplant
Re: Evinrude 4 hp won't pull gas from tank
Check the connections for the hoses that attach to the little square fuel pump on the carburetor. Make sure they're tight on both ends. A leak here can cut down on the fuel supply.<br /><br />Also check the fuel bulb. It could be allowing fuel to drain back into the tank.<br /><br />If you need a new fuel pump, it's available as part number 0388684. I don't believe it's rebuildable. About $40 or so.<br /><br />You can test the pump by disconnecting the hose that goes to the engine's crankcase. Squeeze the fuel bulb. If fuel comes out that hose, the pump is bad.
