Evinrude 33hp Fastwin weight?
Newyota
Thanks. Confirms what I was researching. I will look at the 76 parts
Newyota
The 1962 / 64 model 28 and all the 33 / 40 hp manual shift use the same tiller handle.-----You need to remove the short gear shaft on the motor.----And you need the shaft installed that connects with the shaft on the tiller handle.
I found this on the 28hp 1963 parts list.
