Re: Evinrude 1987 110HP Reed Valve Interchange
Welcome w2!<br /><br />Using "used" reeds, if that's what your looking for, really ain't a real wonderful idea. You might get hold of reeds that are bad or bent and you don't want to flop them over as they may end up as scrap over the piston. New reeds are still available from your local John/Rude Dealer.<br /><br />Consider new reeds or install Boyesen two stage reeds. The Boyesen reeds take a little more work to install and you'd have to make some changes to the idle air jets but they are a definate plus for the engine. I installed them in by 86' Rude 90hp.
