augusto rivas
Thread starter- Joined
- Feb 24, 2015
- 9
Good morning, everyone. This is my first post on this site. My name is Augusto Rivas and I am from Mendoza, Argentina. A year ago we bought a 1969 Evinrude 85hp engine model with hydroelectric gearbox. The gear command (switch control) was broken so I searched for information on the web and on this page I found a solution to make it work with individual keys, and now the reverse and the neutral work but I have trouble with the forward gear. It sometimes assembles the clutch well but sometimes it doesn?t. It?s as if there was no assembly at all, exerting force on the axis of the propeller. The oil we are using is the atf DEXRON 2 since the co Premium blend of brp isn?t very easy to get here. I wanted to ask you if it can be a problem that the clutch is stuck and if disassembling the gearbox is the best solution. You can also tell me if I can do this job myself or it?s too complicated. Thank you very much for your time. Regards
