Hi, I purchased the rebuilt kit and try to clean the carb. Reinstalled everything but engine won't stay running. It floated a low iddle and won't gain power. I had a little fuel coming out of carb so I figured it has something to do with the floater. I put back to original float (which was not too broken) but keep having the same problem. Fuel pump is ok and all the seal have been changed. I did find a threat on other iboat forum regarding the floating and had mine level at the same height. I tried other adjustement such the front needle but with no succes. The only piece I didn't change is the carburetor nozzel gasket. The one that came in the kit was in cork and less thick then the original one (Which is in rubber). Not sure if it is important... I missing something?
Also, There is another piece that is attached with the carburetor which I'm not sure how to adjust. From what I found, it is an automatic choke regulated by a solenoid. There is a litlle compartiment with a spring coil in it that give tension to the choke valve in the carburetor. There's an inscription on the top saying Lean with an arrow. I did try to turn it but doesnt seem to do any good. Does anyone know how to adjust it?
Ok so I'm afraid I completly messed up this engine... and need help.
Thanks in advance
Thanks in advance
