evinrude 1967 40HP carburetor rebuilt - Help
gaoyong
Hi, I purchased the rebuilt kit and try to clean the carb. Reinstalled everything but engine won't stay running. It floated a low iddle and won't gain power. I had a little fuel coming out of carb so I figured it has something to do with the floater. I put back to original float (which was not too broken) but keep having the same problem. Fuel pump is ok and all the seal have been changed. I did find a threat on other iboat forum regarding the floating and had mine level at the same height. I tried other adjustement such the front needle but with no succes. ​The only piece I didn't change is the carburetor nozzel gasket. The one that came in the kit was in cork and less thick then the original one (Which is in rubber). Not sure if it is important... I missing something?
Also, There is another piece that is attached with the carburetor which I'm not sure how to adjust. From what I found, it is an automatic choke regulated by a solenoid. There is a litlle compartiment with a spring coil in it that give tension to the choke valve in the carburetor. There's an inscription on the top saying Lean with an arrow. I did try to turn it but doesnt seem to do any good. Does anyone know how to adjust it?
Ok so I'm afraid I completly messed up this engine... and need help.
Thanks in advance
RCO
The nozzle gasket is very important. If it isn't sealing the motor will draw unmetered fuel and flood itself out. Float should be level with the carb flipped upside down. The automatic choke can be a problem on those as well, set it to manual until you get the motor running right.
oldboat1
I would adjust the choke back to where it was originally -- don't remember how to set it for manual operation but if you have that handled, do it (like RCO suggests).
If you are confident the carb is properly cleaned and assembled, try adjusting the needle again (top of the carb, air/fuel mix). The initial setting is about 1 1/2 turns out, and you adjust from there. (Don't do it on muffs.) Slight adjustments (1/8 turn increments). Too rich, and the engine will stumble. Too lean, and it will backfire. RPMs increase as you lean out the mix (throttle down and go back to adjustments). When properly adjusted, the engine should idle smoothly in gear at about 650 rpms (slow idle), and go in and out of gear without stalling.
I have the same carb on a ?68
Carb should be cleaner inside than outside, does the butterfly look like a gold coin? As well as everything else. Should look brand new inside (It really helps)
Low idle screw set at 7/8 turn out and adjust from there. Motor needs to be fully warmed up as these old motors were built to much looser tolerances than modern motors Make sure the packing for low speed jet is all there,( cork and plastic washers), as it seals the passage in the carb
Auto choke- solenoid is probably the problem, Adjusted from outside of housing loosen screws and turn cover, these things never worked well on any motor. It?s like $140 to replace so I manually set my choke when I start up (almost all the way closed) Lever on side of carb does this and is easy as the motor has a hood built into the cowl for easy access.
Once it starts give a little throttle and immediately fully open choke. I find I do not need the choke any more for the rest of the day
Check the cam attached to the rod that goes to the carb and to the top throttle shaft the on side of motor as this was removed for rebuild and the rod position needs to be reset
Make sure clip is attached to float in fuel bowl as this part was changed. Originally no clip
Factory RPM settings are usually to low as the motor has aged and will need to be raised slightly
