Evinrude 1959 5.5
Brian S
Where is a site that might have a listing for a complete carberator for this engine. The serial number is hard to read. Goes something like 551851?9.Thanks for the replies.
R.Johnson
Re: Evinrude 5.5 1956 0r 1957 model
I may have one of those carb's. I'll check in the morning.
wbeaton
5518 is a 1959 Evinrude 5.5 hp.
samo_ott
Is the cowling blue/white metal or ugly blue/white fibreglass?
Brian S
ugly blue and white fibreglass. Seriously thinking of throwing it away. It seems to be not worth the bother.
samo_ott
Those 'breadboxes' sure are ugly. It was the first year of the fibreglass hood. They are great running engines when running properly. Why do you need a new carb, usually just a cleaning and adjusting will do it.
Brian S
not sure if someone has put on a different carb as the one on there now only has a slow speed adjustment no high speed. Not sure if this carb will work is why I wanted a new carb with both adjustments. I have had the carb that is on this engine cleaned by a shop but they could not get it running smoothly. Runs at med to high throttle in gear but the minute you go to slow it down it stalls..
Brian S
1959 5.5 evinrude Ugly fibreglass model
If the air supply line to the pressurized tank leaks, will the engine keep running at med to high throttle but stall when it is cutback to idle speed. I am in the process of thinking of bypassing the connection and going directly to carb and fuel line. It leaks at the connection where engine and hose from portable tank connect. Would this do damage to anything to try? Back yard mechanic with a little knowledge(very little) just giving it a try.
Thanks
samo_ott
Re: Evinrude 1959 5.5
No it would not hurt to try and a leak there could cause issues. You can fix the connector where it leaks also. There are 2 little O rings in there that are $2 each at the dealer that can be relatively easily replaced and it makes the connector good to go again. Those connectors are $130 new (yes, $130!) so it's a good idea to put new O rings in it :)
