superfluke82
Thread starter- Joined
- Jul 1, 2017
- 7
I'll tell whole story and what ive done to best explain where im at.
My neighbor has 1975 evinrude 15hp model 15504C. he's had it for a year and it ran great. The motor began to lose top end and wouldnt idle at slower RPM. Before i began to work on it the motor would start first pull but only idle at high RPM. When boat was in gear it would not throttle up much but it would run consistent no sputtering or surges.
1)I removed carb which seemed to have a small leak from bowl but carb looked good. I cleaned it good and rebuilt it with kit.
2)Fuel pump was full of crap and wasnt working right. I replaced it
3) New fuel line with new clamps and filter added inline.
4) new spark plugs added which were recommended for that motor
5) compression is 95 in both cylinders
6) roller ram on carb is rigged with a drywall screw. but it appears to line up well with timing base and base moves well
7) stop switch is disabled
Motor will start but only run at high rpm. motor starst to die some until i tap throttle and it'll go back. Boat in gear still does same thing and wont go much higher that high idle. I have idle knob set on 2 turns out. Bottom cylinder has alot of unburned fuel and oil in it
Ive looked motor over more and have realized the block has a model number 10R78M. motor has a power pack (which has manufacture date of 2014)and new looking coils. Carb is for a 15HP.
I have no clue where to proceed. Is there a way to tell if 10R78M was converted to a 15? doesnt it need a different header and reeds?
I can post pictures just let me know what you need picture of
Im sorry if i got confusing
