EVINRUDE 155hp Starter Rotation
mav6759
I'm having a issues with my starter, the bendex does not engage the flywheel. I want to know if anyone knew which way the starter is suppose to rotate to crank the motor. The starter is spinning clockwise which rotates the flywheel counter-clockwise. If I rotate the bendix counter-clockwise by hand the bendex climb's the shaft of the starter. But the direction that it is spinning now it is not climbing.
Will Bark
Have you messed with starter and gotten it 180 degrees out? The starter spins counter clockwise to spin the flywheel clockwise. Take it to a starter repair shop to get it serviced. Good luck
