FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
if stuck down there is a manual release valve (#66) that can be opened by a screwdriver on the starboard side of the unit. this will enable you to lift up the motor and apply the trailer bracket.Then on the fluid reservoir (#63) there is a flat head screw (#30) remove this and top up with t&t fluid. put back in the screw and move the motor up and down a few times to get rid of any air in the system , open up the screw and top off with fluid again.
