evinrude 150 hp ficht wont start HELP
badcummins99
I have a 2000 150hp evinrude. When i turn the key on it goes thought the system check. (no oil)(water temp)(check engine) Then all three start blinking, and it wont roll over. It just clicks and one of the fuse are clicking in the engine compartment. My batterys are charged up because if I jump the solenoid and it will roll over
tashasdaddy
Re: evinrude 150 hp ficht wont start HELP
90% of starter problems are bad connections. remove and clean both ends of the battery cables, so that they are shiney, also the cable from the solenoid to starter. check for nicks in the cables. and make sure the connectors are on the wire good. the cable tend to corrode from the inside out, if nicked, corroded wires, and connections, heat up and cause resistance to the follow of electricity, thus the starter doesn't get enough. you can also take jumper cable pos battery post to large post on starter. with a good connection, the engine should spin. then if the starter is good clean everything and retest. then trouble shoot solenoid. starters can be rebuit at a starter/alternator shop, much cheaper than a new one.
also have the battery load tested at the auto parts store, free, i've had new batteries go bad
badcummins99
Ya i think its my batterys, does the waning lights flash like that if the batterys are bad?
HighTrim
Have you tested the voltage across the battery, 12.65 volts? Also have it load tested as Tash stated. Clean all those connections until they shine, you cant just look at them and assume they are ok. Inspect the entire cable, especially where the cable enters the terminal, for bulging of insulation which is a sign of internal corrosion. Replace the cables or cut the ends off and install new ones as required. DO not overlook any of the battery/starter/solenoid cables and/or connections. Including ground.
If it now works, great, if not, use a short jumper wire to short the small terminal on the solenoid to the large terminal on the solenoid (the one that has the POSITIVE battery cable connected to it). Be prepared for a spark. You are essentially doing the same thing that the ignition key does in the START position. If the engine spins fine every time, you either fixed the problem, or if not, the problem is in the harness between the engine and ignition switch.
Disconnect and inspect the large harness plug in the engine compartment. Clean it as best you can and reconnect. Now use the ignition switch to try and start the engine. If it works every time the connector was the culprit. If not, you now need a voltmeter.
Put the POS voltmeter lead on the small terminal on the solenoid. The NEG lead goes to ground. Have someone turn the ignition key to START. If you don't see 12V troubleshoot the harness between the engine and control box. If 12V is present every time, the switch is good.
At this point, connect a single jumper cable between the POS batter terminal and directly to the large terminal on the starter. If the starter spins each time you do that, the solenoid is likely the culprit but there is one more test.
Connect another jumper cable to the NEG battery terminal and a good ground (bare bolt head or bracket) on the engine. Now do the same test you did previously. If the starter now goes ok, you still have a negative battery cable problem or the solenoid is bad. If it still doesn't work right, you have a bad starter.
Alternatively, get yourself a multimeter and measure the voltage at the starter (+) terminal while somebody turns the key over to "start" - if you get within half a volt or so of the battery voltage, the starter is faulty. Try turning the bendix a 1/4 turn, if it now fires, the brushes in the starter could be at fault.
Bad voltage at starter (with clean tight connections), measure the voltage at the solenoid small terminal with the yellow/red wire with the key turned over to "start" you should read within a half-volt of battery voltage, otherwise you have a wiring fault beween the keyswitch & solenoid. Good voltage at solenoid but bad voltage at starter means faulty solenoid.
D
DJ
Guest
Don't forget to clean the negative battery cable where it grounds at the engine block.
