Evinrude 115HP Fuel Leak
gtxnoclue
Wondered if you might be able to help me solve this. My boat has been running fine. Had actually cleaned the carbs at the end of last year. The other evening, it started sputtering at no wake speed then it died. The fuel tank was pretty empty. Changed tanks & it took a little while to get it started. Finally started, but was exhibiting the same problem. Ran it the next day. Sputters at idle. When starting off WOT it doesn't come up to plane as fast as it normally does, but planes off & seems to run fine (and sounds normal). When backing off to idle it again starts to sputter. Occasionally when it sputters, looks like air bubbles coming from the lower unit (underwater). I put new plugs in with the same result. Here's where it gets interesting. After it sat overnight, walked out just now to work on it a bit. Smelled like gas around the dock. It looks like about 2-3 gallons of gas has disappeared from the plastic gas tank. Saw fuel dripping from the front of my tilted motor. The gas tank was lower than the motor, but the tank did seem pressurized from the suns heat. Not sure how it "Leaked uphill" other than maybe from a partly heated/pressurized tank
So not sure what to do next. Maybe pull the boat out, tilt the engine & see if I can see where it's leaking from. From other posts, see where the sputtering issue may be air getting into the fuel system somehow or debris from the tail end of the initial gas tank. Would like to troubleshoot this smartly, so I don't end up creating other variables that will come back to haunt me. Any advice would be appreciated. Thanks for your help!
jakedaawg
Is it one of the new EPA tanks? If so you will have to find a solution to the over pressure. They don't vent anymore because the greenies think that's gonna solve all the problems.
if it's the classic tank you may need a new cap.
either way you need to find the leak. Common place is the VST lid gasket, warped carb bowls, joint at cowl.
slightly tilt engine up. Just so carb throats have a slight forward lean.
squeeze bulb til firm. Continue squeezing gently and note whether or not bulb continues to depress. Look for leak.
you're not trying to crush the bulb, just keep pressure on it.
gtxnoclue
It is an EPA plastic tank so I guess I can worry about that next. Took the boat out of the water to be able to see better. Plugged the fuel line back up & pumped the bulb (arrow pointing up). Doesn't ever seem to get firm but I think it's 1 of those double walled bulbs so may not have felt it. But when I tilted the motor up gas poured out from the front plate of the carbs (may have tilted & squeezed too much). Couldn't see any leakage around the fuel filter or anywhere else. Took the front plate off to see the carbs but couldn't tell where the gas was coming from.
BTW - Don't know what's meant by "joint at cowl". Is that the fuel connector at the engine side (PN 394313)?
Researching VST, it looks like it might be 1 of the gaskets on the fuel pump (I assume part of the VRO pump). I did have issues with my VRO pump last year. Service tech removed the oil portion of the pump so I mix oil directly in the tank now. Had some fuel issues afterwards. Ordered a VRO pump repair kit & rebuilt it with the new parts. Things seemed to run great after that work was done (saw a pretty big split in the original diaphragm).
I will try to see where the gas is coming from again tomorrow when there's a bit more light (weather permitting). And I promise to try following your advice more closely - slight tilt and gentle squeezes. Think I messed up the 1st try. Any additional thoughts in the meantime would be appreciated. And forgot to mention - my motor is a 1991 model.
Thanks so much for your help!
89retta
Have you tried leaving the fuel cap a little lose ?
gtxnoclue
Went out to try again with a flashlight. Slight tilt & gentle squeezes. Didn't see any leaks. Fuel filter was full (1 small air pocket). Wondering if the pressure from the warm plastic tank allowed the gas to flow through the carb bowl since the engine was fully tilted up at the time.
Also - when troubleshooting the sputtering at low idle the other day (prior to the leak) I noticed that the fuel filter had a very minimal amount of gas in it while the engine was running. Is this normal or should the fuel filter always be full while the engine is running. If it should stay full of gas, what would cause it to be "dry"?
Thanks again!
gtxnoclue
Have not tried loosening the fuel cap. Should I try that with respect to the sputtering or while trying to find the leak (or both)?
gtxnoclue
Was about to call a repair shop & take the boat in. Figured I'd try a few more things. Running on muffs, I tried loosening the fuel cap with no luck. At some point, the fuel line connector just fell off the tank connector (the male prong type with guide pin). Swapped it out with the 1 that came with the tank (cheap plastic fitting that locks on). Cranked it up & it seemed to run great (same idle as before the problem arose). Fuel filter stayed pretty empty at idle but from what I've read online it looks like that's normal. Will try it out on the water this weekend.
I'm feeling pretty stupid at this point, but also very happy if that's all it was.
If it runs good then I'll chalk it up to low fuel in the 1st tank for the initial sputter & engine cut off. Then the poor connection to the plastic fuel tank creating the continual sputtering & cutoff. Then the tilted motor & pressurized plastic tank from the sun creating enough pressure to force the 2-3 gallons of gas to leak through the carb. If that's the case then I guess I'll have to go buy 2 more plastic tanks since the old OMC metal tanks with male prongs don't make a great seal anymore (and I'd have to swap out connector types each tank change). Suggestions on tank type & what to do about venting the plastic tank would be appreciated.
Thanks again for all the help Will let you know how it goes this weekend.
jakedaawg
Sorry I have been to busy to keep up with this. Missed a bunch.
1. Any bulb should get hard. If it does not there is an issue somewhere. The bad fuel fitting certainly could contribute.
2. Yes, joint at cowl was referring to where you plug the line into the motor.
3. When running, those "see through" filters do not stay full. Normal.
4. If motor was slightly tilted and you were squeezing bulb and fuel was comi g out carb throats then you have a needle and seat/float issue. If motor was tilted way up, almost horizontal, then some fuel loss from carb bowls is normal.
5. Can't remember what question was next.
gtxnoclue
No worries at all. Jakedaawg & 89retta - Thank you so much for your help & advice. My son has been riding the boat quite a bit & it's been running great. And no more leaks - we've been disconnecting at the tank and loosening the gas cap after use so that we can tilt the motor out of the water. Have 2 universal sprayless connectors on order so that we can try to still use our old metal gas tanks (will tie wrap the standard connector with female slots for the prongs to the metal "ear" of the tank to keep the spring loaded pins from forcing a gap where it mates. Will then put the sprayless connector downstream of that. If that doesn't work, my son found gas caps with vents in them that we will order along with 2 more plastic tanks so the pressure doesn't build up (will replace the 2 older metal tanks). Thanks again for all the help!
