Wondered if you might be able to help me solve this. My boat has been running fine. Had actually cleaned the carbs at the end of last year. The other evening, it started sputtering at no wake speed then it died. The fuel tank was pretty empty. Changed tanks & it took a little while to get it started. Finally started, but was exhibiting the same problem. Ran it the next day. Sputters at idle. When starting off WOT it doesn't come up to plane as fast as it normally does, but planes off & seems to run fine (and sounds normal). When backing off to idle it again starts to sputter. Occasionally when it sputters, looks like air bubbles coming from the lower unit (underwater). I put new plugs in with the same result. Here's where it gets interesting. After it sat overnight, walked out just now to work on it a bit. Smelled like gas around the dock. It looks like about 2-3 gallons of gas has disappeared from the plastic gas tank. Saw fuel dripping from the front of my tilted motor. The gas tank was lower than the motor, but the tank did seem pressurized from the suns heat. Not sure how it "Leaked uphill" other than maybe from a partly heated/pressurized tank
So not sure what to do next. Maybe pull the boat out, tilt the engine & see if I can see where it's leaking from. From other posts, see where the sputtering issue may be air getting into the fuel system somehow or debris from the tail end of the initial gas tank. Would like to troubleshoot this smartly, so I don't end up creating other variables that will come back to haunt me. Any advice would be appreciated. Thanks for your help!
