Fishing4life
- Mar 23, 2010
- 1
I have a early '90's Evenrude 48hp SPL. I bought it w/ a boat 3 years ago, ran it 3 seasons out of the year untill this winter. It won't start now. It turns over, getting spark, and has fresh fuel. Put the "muffs" on it, water pump works fine. When i bought it, I replaced the gas tank and fuel line w/ bulb. I have been running it 100/1 mix, as the pervious owner did. The sticker on the side of the engine next to where the fuel line plugs in says 100/1. I've heard I should be running 50/1 mix. When it was running, it took 5-15min of cranking for it to fire, then I would have to play with the idle untill it warmed up. When it was running half to open throttle, it sounded like it was missing every few strokes, and would shake a bit.
What do I need to check/ fix to get it running again?
Thank you for your help, I'm trying to get it fixed by this weekend so I can fish a tourny.
