I will have to pull it off again, it only leaks at the top of the head. at idle it is more like it is seeping but under power it is 3 little streams of water. could it be that I didn't clean the motor side well enough, it was getting dark when we finished putting it back together.
This is a recent purchase, if it has, it was before I bought itHas the motor been overheated?
Yes, at the top of the cylinder headAre you leaking water?
No,How is the compression after the change?
I have check the head on a flat surface, I could not see any gapsThe head will be warped.--------Every one I look at has warped heads !!!!
