Evenrude 115 ( 115999R )?
Aaron73
so I changed the head gasket and read the service manual from the link you provided. the motor is running ALLOT better but there is still a leak from the top of the cylinder head, what should my next steps be, should I remove the head again and clean the surface with some sandpaper?
sutor623
Has the motor been overheated? Are you leaking water? How is the compression after the change?
I ALWAYS clean up the mating surfaces before changing a gasket. Maybe set the head on a piece of glass and see if it is warped. If it is warped it can be hard to sand it down back to flush.
The head will be warped.--------Every one I look at has warped heads !!!!
Aaron73
I will have to pull it off again, it only leaks at the top of the head. at idle it is more like it is seeping but under power it is 3 little streams of water. could it be that I didn't clean the motor side well enough, it was getting dark when we finished putting it back together.
sutor623
Well, first off, you haven't answered all of my questions from post #4.
Secondly, Racer says everyone he has seen has been warped. I'd pull it off and have it machined or just buy a new one or NOS IF you can find one.
Keep in mind, if you do get one milled you will have to pull both heads so that the compression is the same between both banks. No telling how much they will have to mill in order to get a flush seal.
Aaron73
This is a recent purchase, if it has, it was before I bought it
Yes, at the top of the cylinder head
​No,
I have check the head on a flat surface, I could not see any gaps
I did learn that my friend who helped me tightens, heats and retightens the bolts
