Etch ?
MAXXIE
I contacted the Durabank Co. awhile back asking about prep involved in applying their product to a galvanized trailer. They said the metal needed to be "etched" first & then it can be applied. What is etching & how is it done?
Brewman61
Ensign
Re: Etch ?
Etching prepares the surface so it holds to applied product better. Usually the idea is to roughen it up a bit giving the product some extra surface area to grab. Very often some type of acid is used.
MAXXIE
Re: Etch ?
Acid treat the entire trailer? Guess I'll just wire wheel some of the surface rust off the fender & leave it at that. Thanks, MAXX
Re: Etch ?
Ayuh,... Galvanizing is an aluminum product...
It has to be treated exactly like painting aluminum....
robert graham
Re: Etch ?
A surface can be etched for painting or zinc galvanizing by sandblasting it down to the bare metal, then prime and paint. There is a zinc "cold galvanizing paint" that can be bought and applied, but it's probably not near as good as real dip-tank zinc galvanizing. No need to spend more time and money on a trailer than it's worth, especially if it's all eat up with rust and corrosion. Sometimes the worst corrosion is on the inside of the channels, tubes, rails, and you can't even get to it with paint.
jeeperman
Re: Etch ?
Galvanizing is a zinc product.
The galvanizing forms a somewhat unseen oxide layer that can be rubbed off by hand.
If that oxide layer is not removed just prior to painting, the paint tends to peel off as it has only really stuck to the oxides.
Etching with acid can be done via wiping it down with an acid soaked cloth.
The paint or coating manufacturer should be able to provide the name of the exact stuff that works best with their coating.
