farmer9009
Thread starter- Joined
- Aug 23, 2009
- 69
While researching supplies for my upcoming project I ran across this statement from a supplier "Chopped strand mat contains a binder which prevents proper bonding with any epoxy resins. Use our polyester or vinyl ester resins with chopped strand mat."
This statement is at the bottom of this link:
http://www.fibreglast.com/product/System_2000_Epoxy_Resin_2000/Epoxy_Resins
I never saw it mentioned anywhere else to not use Epoxy resin with CSM.
If this is the case what should I use in place of CSM when using epoxy resin? For example when installing a new sheet of plywood transom to the existing hull of the boat. I understand epoxy has the best adhesion qualities and from what I have read CMS is preferred for this due to its moisture sealing qualities.
Thanks.
Thanks.
