Engine
jeffreymhunt
Hello:
I purchased 1987 Thompson ,with mercruiser I/o with Volvo 260A .
Is this GM made engine?.
Thanks
Don S
Re: Engine
It's called as junk yard dog.
Yes, a Volvo 260 is a 5.7 engine GM engine, and Mercruiser also uses a 5.7 and it is also a GM engine. But Volvo and Mercruiser are competing companies. If you have a Mercruiser outdrive and transom shield, and a Volvo engine, then some engine out of a volvo and adapted it to fit the Merc drive. A big mix of parts. Aka, Junkyard Dog.
Doesn't mean it doesn't work, it will just be a chore at times to figure out what part is Volvo, what part is Mercruiser, and what parts may be homemade.
jeffreymhunt
Re: Engine
Hey thanks for info .
Now for big question, water in No. 8 cylinder it has 150 lbs compression.
Thanks
Re: Engine
Thanks
Ayuh,.... Welcome Aboard,... Probably from junk/ rotten/ rusted manifolds, 'n/ or risers...
