slag
Thread starter- Joined
- Jul 17, 2009
- 471
I originally took this video to come on here and ask about the exhaust gases coming up through the hole, but I found another post where a guy said to just inject silicone sealer to encase the wires and let it cure to seal off this hole. I didn't have a rubber grommet and didn't know to do this.
http://forums.iboats.com/showthread.php?t=322334&highlight=exhaust+shift+hole
Anyway, even with the cowl off, this runs rough. It won't idle at the right point, but it will idle. I recently rebuilt the carbs and cleaned under all the welch plugs. Set the screws to 5/8 turn out as said, but have turned them up to 1/4 turn each way with no effect. I have spark on both cylinders as well. Compression is good. What am I missing? The engine doesn't get hot and the gas is fresh running 50:1
