Engine stalls when shifting
mendler
I have an '89 mercruiser. My problem is that every time I try to shift into gear (fwd or rev) the rpms dive and the engine cuts. I can start up no problem and in idle it sounds fine. The engine and rpms sound and act normally when I use throttle only.
I have had trouble previously with the engine stalling when going from gear to idle. Now I can't even get into gear. Could it be a shift cable replacement could fix this problem?
K9Deuce
Re: Engine stalls when shifting
Shift cable, check the sticky section there is a great write up on it..
a1nowell
mendler,
As mentioned, you are probably due for a shift cable replacement. I was able to get a few more months out of mine by tinkering with the shift interupter switch but finally had to replace the cable.
Larry
Ayuh,.... Welcome Aboard,.... More than likely, Yes, that's yer problem, 'n the cure is to replace it,...
