Engine runs rough at High RPM's 40 HP Evin
boss5184
My 40 HP Evinrude run fine til about 2500 -3000 rpms. Then it tries to red line.I have pull the thottle back .It starts and idles fine. Any ideas?
F_R
Re: Engine runs rough at High RPM's 40 HP Evin
By red line, you mean it races like it is slipping? Does it make any terrible grinding noises when it is doing that? If not, then it is either cavitating or the propeller hub is slipping. Most likely the hub.
To find out, make a mark on the plastic prop cap and another on the propeller itself, aligned with the first one. Run the motor till the suspected slippage occurs. Stop the motor and see if the marks are still aligned. If not, it has slipped. Either replace the prop, or have yours re-hubbed. You can't re-hub it yourself, you have to send it to a prop shop.
boss5184
It does this out the water on a hose.
F_R
What??? Stop doing that before you blow it up. Never run above fast idle on the hose. It is doing what is called runaway. It was meant to run on a boat in the water.
boss5184
It does the same in the water.
F_R
You lost me. By in the water, do you mean in the water and in gear or in neutral? If in gear, see my previous reply about checking for a slipping prop hub. If you are still revving it in neutral, see my previous post about don't do that.
