Engine revs when I turn
Susquehanna Squid
Hello everyone! I was wondering if anyone would be able to tell me why my engine revs when I turn. I have a 2005 Monterey 180fs with the 3.0 Volvo Penta. The boat runs awesome but when I get into my turns the engine revs and it sounds like the prop is "breaking loose" (cavitation?) in the water. You definately notice a loss of power when it happens. I can correct it by throttling back but I should not have to do that. Any advice?
Grand Larsony
Re: Engine revs when I turn
Read up on ventilation vs. cavitation. They're different. May need to trim the drive down on some boats as you approach a sharp turn (not that I've experienced this myself).
Fireman431
Your gathering more air under the boat and into the prop, allowing it to rev higher. As stated, trim down or decrease the speed/sharpness of your turns.
That happens on some hulls, especially Deep Vee hulls with lots of deadrise at the stern. Flatter sterns don't do it as much. Take a look at the antiventilation plate while on plane, going straight. Then in a turn. let us know what you see.
jmarty10
Happens to me all the time when I'm doing a hard turn. Trimming down did help me this weekend but not totally. I have to slow down and trim all the way down then open up throttle.
Susquehanna Squid
I will see what trimming down does for me. As for throttling back or not turning as sharp, I still have the problem at 2/3 throttle even if the turn is not very sharp. Will a hydrofoil help?
Fireman431
No. people use those to help a boat plane out.
