engine problems 07 60hp bigfoot
bigfoot07
hi the question i have is my 07 60 hp bigfoot merc won't go above 3000 rpm's.my dad put a new prop on it on saturday and was getting 5500r's and 20 mph.he then docked it got on it on sunday and it went from 4000rpms down to about 3000-3200 rpms.he switched back to the old prop and it stayed the same.i'm thinking fuel issue but not sure and won't be able to look at boat until saturday.does any one have any ideas or had the same issue.
1nebel0
Re: engine problems 07 60hp bigfoot
Check the stator using the procedure outlined in many posts and manuals..you need a digital meter and peak voltage adapter....also check the fuel bulb and make sure it is firm and you are not sucking air...
