Lou C
- Nov 10, 2002
- 14,368
part #10 can crack and the irregular o ring part #8 that fits into the pivot housing can slip out of place when installing the drive, either can cause an air leak. Same design as the OMC Cobra. When I install the drive I use some OMC triple guard grease to hold #8 in place. If you disconnect your raw water hose at the impeller, tilt the drive up and fill the hose with water, see if you see any leaking where this part #10 is or the joint between the drive and the pivot housing (o ring #8). Believe it or not I have the same plastic fitting on mine that was on it when I bought the boat 18 years ago, they can crack if water is still in the drive and its not tilted down in cold weather. The Cobra has a drain plug just outside of where that is, not sure about the Volvo. The plastic part actually has a small hole in it to allow it to drain out of that drain plug (#9 in that diagram).
