nola mike
- Apr 22, 2009
- 6,111
I think gas and water are both liquids. Am I wrong?![]()
Depends on the temp
Is the click coming from the starter? Wasn't clear...
Wow, that's rusty! I bet the starter gear was freezing on the shaft, or the bearings on the shaft are shot. If there's no core on that and you're really interested in learning more, tear it apart. It's already a boat anchor, might as well tear it down and find the failure point.
All good, but if you did not say that we would have said start with cleaning all connections. We thought everything was clean and tight. My guess is if you saw it was this bad you would have cleaned before posting
