Shamfarlango
Thread starter- Joined
- Mar 20, 2011
- 142
the specs:
I have twin 3.8L OMC outdrives (1985) with 800 Series stringer outdrives.
Both are running the same props (15x15.5 Aluminium 3 Blade).
Last season, it was recommended that i get my timing checked..so I did.
I also had the points and idle configured.
The throttle has full play but when i lay the two sticks down, one tops out at 3000 RPM (Other is about 3900).
I suspect I am incorrectly sized from a prop perspective, but I would like to get the engines working in sync before doing any prop purchases. As it sits right now, there are brand new props on the boat and they are identical.
So...
If the timing is right, idle, points are all configured...what are my next steps that could be limiting the potential of my engine?
So...
