joshkeys19
Thread starter- Joined
- Aug 19, 2003
- 1
Today when out on the water I recieved a very large shock from my control box and when I turned the key to turn off the motor nothing happened.. it just kept running.. after starving it of fuel and forcing it to shut off I tried to start it again with no sucess.. I then found that I had blown the starter fuse and replaced it and thought I found a live wire in the control box so I taped it up ( I didnt have a mulimeter with me to confirm it was live). Well 30 minutes later after boating for a while I recieved a much smaller shock as I didnt grasp the throttle but just brushed it and so I tried to shut it off and it would not again.. So I did the same thing and now am not sure what is going on. I still think that there must be a live wire in the control box but I cannot see any.. does anyone know of or had anything like this before? This is not the original throttle.. but the motor is a 73 johnson..and the throttle is probably from around then too.. it is a white metal case with the choke applied by pushing in the key. and a warm up lever on top of the throttle. Thanks for your help
