Engine not turning off and "live" control box
joshkeys19
Today when out on the water I recieved a very large shock from my control box and when I turned the key to turn off the motor nothing happened.. it just kept running.. after starving it of fuel and forcing it to shut off I tried to start it again with no sucess.. I then found that I had blown the starter fuse and replaced it and thought I found a live wire in the control box so I taped it up ( I didnt have a mulimeter with me to confirm it was live). Well 30 minutes later after boating for a while I recieved a much smaller shock as I didnt grasp the throttle but just brushed it and so I tried to shut it off and it would not again.. So I did the same thing and now am not sure what is going on. I still think that there must be a live wire in the control box but I cannot see any.. does anyone know of or had anything like this before? This is not the original throttle.. but the motor is a 73 johnson..and the throttle is probably from around then too.. it is a white metal case with the choke applied by pushing in the key. and a warm up lever on top of the throttle. Thanks for your help
jimchere
Re: Engine not turning off and "live" control box
Turning off the ignition switch actually closes a circuit that grounds out the spark ignition system. This wire that grounds out your spark system runs all the way from the engine, to the control box, and back to the engine grounding on the block. Sounds like this wire has come loose inside your control box. Yes it will shock the snot out of you (high voltage/low current) much like grabbing a spark plug wire on a car while someone cranks the engine. I would open up the control box and find the loose wire or maybe its frayed insulation but since your motor won't stop with the key its probably come loose.
