I’ve had this symptom which ended up being a loose carb gasket seal, which lead to the engine being flooded. Had to wait about half hour to restart it, or manually open the throttle when cranking to dry out the engine. Just pull a plug to see if its wet, if so, then youll know that it gets flooded when starting warm.
