Engine keeps dying after 6-7 minutes??
Flyingdragon_uk
Hi,<br /><br /> Thanks for all your help in my previous questions, u've all been most helpfull, I have a little problem thats bugging me.<br /><br />On my 5hp outboard (Penta), it starts and runs fine, but after about 7 minutes it just dies, after about a minute its starts ok and is ok for another 7 minutes, and so on......<br /><br />The carb has been cleaned and its not situated near anywhere hot, could it be the plug?? as its just a old plug i had lying around as i dont know the correct plug type.<br /><br />Any ideas anyone?<br /><br />Thanks,<br /><br /> Graham.
roscoe
Re: Engine keeps dying after 6-7 minutes??
??? weak fuel pump??? maybe, if your engine has one. Or and air leak in the fuel hose or primer bulb?<br /><br />Does it have a primer bulb in the gas line? If so, try pumping it up while engine is running. Do this every couple of minutes.<br /><br /> If it keeps running, then at least you have narrowed it down to the fuel system.
POORBOY
sounds like a coil getting hot and shutting down then when it's cooled it starts up again, just a thought
G DANE
Hi again Graham<br /><br />The fuel pump can be checked like this: When the motor stops after 7 minutes, carefully pull the fuel hose that leads from pump to carbureator off the carbureator. Pull starter rope. If fuel squirts out of hose in small squirts, pump is OK. Look out that the fuel doesnt hit anything hot, as far as I remember exhaust manifold is very hot on this model. Is your tank vented ? If so try to run it with cab off, it could sound like it cant pull air in, to replace the used fuel. Lack of tank ventilation will cause pump not to pump. sorry for this long reply. Let us know.
Flyingdragon_uk
Thks, will take boat out in the next few days and do a few tests on the engine!!<br /><br />Graham.
Backlash
Sounds like it could be an unvented fuel tank.<br />Backlash
rob48329
might be overheating caused by lost water pickup on underside of cavitation plate, or leaking seals at either end of pipe that takes water up from there to one side of the exhaust manifold. ( whereupon the water runs back down another channel on the other side of the manifold and then drains out inside the leg and out the exhaust vent at the back of the cavitation plate just behind the pickup I mentioned)<br />Or simply restriction caused by partial blockage generally (corroded aluminium) throughout this waterway.
neumanns
My guess would be fuel tank ventilation followed by restricted fuel flow at a filter. Let us know your findings.
JB
I sort of think that after a year, Dragon has solved his problem one way or another. :) <br /><br />Moving to Other Outboard troubles.
sea king 5
does the engine have a rubber fuel line? if it does then change the line,it may callapse under pressure and stop the fuel from getting to the carb,I didn't see a reply of that natiure
sea king 5
One more thing,never put old plugs you have just laying around in a engine you are having problems with,it could be your plug or rather your fuel mixture,if you are runing rich you will fowl the plug and it won't fire,the engine is hot,and it dries the plug so it will fire untill it gets wet again,and so on and so on!try leaning the mixture a little,or start the mix all over again turn screws 1 1/8 out to start,after you run them in first of corse
