andrewterri
Thread starter- Joined
- Jun 25, 2014
- 437
I have a 1989 sea ray with a mercruiser 3.0 with an alpha one outdrive. I recently got the boat and after replacing the impeller I went to start the engine with the muffs on and saw water spraying out of the side of the engine under the exhaust manifold. After getting that sinking feeling that I have a cracked block and I just wasted my money I realized that the water was coming out of a screw hole. After some reasrch I found it was the drain plug hole. My problem lays in that the threads are rusted solid on the bottom side of the hole. I found that the plug was a 1/4 NPT and bought a couple of them along with a stiff wire brush thinking that I could clean the threads and force thread one plug one there and then use the second one with the good threads, however, this is not working. I tried to call machine shops to see if they can die and tap the hole and they wont because the engine is in the boat. I am worried about doing it myself because I have never done it and don't want to go to deep and puncture the water jacket. Any ideas would be a great help.
TIA Andrew
TIA Andrew
