krustyCrab
Thread starter- Joined
- Jul 1, 2014
- 27
Hey Everyone,
Ill give you the specs first... I have an 1986 OMC stringer powered by a 4.3l v6 262 v6. 8 bolt manifold, rochester 2 barrel carb.
If you look at some of my older posts I talk about white smoke coming from one of the valve covers, I assumed at the time I could be dealing with a cracked block, head, or something like that.
Well I decided to pull the motor at the end of the season, ripped it all down, and generally inspected all of the components. Everything visually looks good, though I think we can agree that doesnt mean a whole lot. Reason for pulling it was to rebuild the engine, new seals gaskets the gamut.
As spring is hopefully nearly around the corner I need to make a decision to proceed with repowering or to procure either a new engine or get into a new boat.
I like the hull I have, i know dealing with a stringer is not necessarily the cheapest or best bet, but the outdrive is in good shape and works well, as much as I was able to test it last season anyway. The one thing that freaks me out, is the exceptionally large transom hole with a simple rubber belows between the engine and the ocean, im sure its fine but it freaks me out a bit LOL
So im looking for advice, should i rebuild the engine, im thinking i would have the cylinders bored out, new rings etc etc, I would likely still have to have the block checked for cracks, along with the heads... I estimate that cost to be somewhere in the neighborhood of 2k, I assume that process would start with getting the block cleaned up and magnafluxed for cracks, at which point proceeding with a rebuild is not an option and im out the 400 bucks to check the block. Option 2 would be to procure a new rebuilt engine, now some questions abound by that, could I go with a newer block, say like a 97 vortec or something like that with a 12 bolt manifold (obviously i would have to get a new manifold) still working within the same specs (4.3l v6). I could then use some of the parts known to be working off my old engine like the alternator, starter etc etc OR should I make an attempt to find a rebuilt engine made with the 8 bolt manifold and match motor for motor?
Lastly the third option is should I just scrap this boat altogether and use the money I have set aside for a new vessel. I could potentially recoup some of the money I have into the boat by salvaging as much as I can from the hull, parting out the outdrive, selling the trailer... Im thinking I could probably get about a grand for some if not all of that stuff.
Rough estimates on cost for what im trying to do, I think maybe 2-2500 for a rebuild. Probably 3kish for a new rebuilt engine, or a new ship altogether for maybe 5-6k.
If your of the opinion that a new rebuilt engine is the way to go, could you recommend some online shops that might carry what im looking for at a decent price, same with the new boat should i go that route, im thinking craigslist for that venture though.
I am mechanically inclined, but i would likely have a shop do all the work on the engine rebuild should i go that way.
Any advice would be greatly appreciated.
PS. A previous discussion in one of my threads discussed the possability of just finding an automotive 4.3l 262 and swapping out that motor on the cheap, a lot of research says this can be done however not recommended due to the marine cam, freeze plugs and things like that. Any thoughts there?
