Keith Buchanan
Thread starter- Joined
- May 10, 2004
- 221
Merc/Mariner 50HP 1990 3 cyl...After having a short overheat I have now changed the impeller, circulation and temperature is again normal..Whilst the lower unit was off I attached a hose to the end of the water take up pipe with the intention of flushing the system and running up the engine to test the t,stat and bypass valve. What I witnessed was the rapid build up of an emulsified residue in the exhaust, this was the first time the engine had been run since the overheat, I ran the unit for 20 minutes and with a flashlight this residue can be seen all the way up the exhaust to the bottom of the powerhead. A:, Is this normal, I cannot say I have noticed this before, otherwise it would be evident at the prop .<br />B:, Is there any gasket etc whereby water could cross into the exhaust at the powerhead, With water circulating and the engine off there is no water coming down the exhaust.<br /><br />Regards Keith..<br />Nearly there..<br /><br />Regards Keith B..
