What's up dudes? Just so you know I am new to boating. Lost my virginity to 1 mile plus waters last weekend. I need some advice on the following situation:
I recently purchased a 1982 Cobia 228 Odyssey 21' CC with a 350 I/O. It's in great shape for its age, but I was very hesitant to buy it because I didn't want to deal with an unreliable engine. When I first went to look at the boat, the seller started it up and it popped right off no problem. After buying it I took it home and hooked it up to the hose and started it. Again it started first try no warm up.
At this point I am fairly excited to get it on the water, so I called a few friends and took it to St. Marks Bay. I had to haul it down some bumpy roads to get it there. When I got it in the water, with all my friends and a bunch of strangers watching, it wouldn't start. I tried and tried. Finally, I pulled it out of the water and tried again. Ill be dammed if it didn't start right up.
So, feeling like I fixed the problem with my PFM, I put it back in the water (keep in mind I wasn't getting much help from my friends launching this 21' boat). I turn the key, and it won't start again. its turning over, but no fire.
So I hook it up, pull it out until the motor is out of the water and try again. I starts on the first try. This time I left it running as I launched it.
After that it ran fine the rest of the day. I went for miles, stopped a few times and every time it started right back up. Even after sitting for an hour or so. Ran perfect. When I got it back home I hooked it up to the hose to run some water through it and it did it again. I ended up pumping the bubble on the gas line 3 or 4 times and after a few tries it started. Has anyone ever had this problem? is it something I should be concerned about, or is this normal for an older engine? Thanks for any advice.
