Electronic ignition for Motorcraft distributor?
ctanke
Greetings,
I am working on a 1972 Mercruiser 888 Ford 302 with a Motorcraft distributor stamped d1jf 12127 MA. I would like to convert this to electronic ignition but can't find any kits for it from the usual manufactures. I am also ignorant of what all the letters and numbers stand for. Please assist. Thanks in advance
Chris
Ayuh,.... Post a picture of it,..... I don't think Merc used Ford distributors,....
ctanke
No Title
Here ya go. My research points out that Motorcraft distributors were a bit more common on Mercruiser 140s. I'm just special I guess having one on an 888? LOL
Thanks Chris
Ayuh,.... The 140 is a GM motor,..... I believe Prestolite or Mallory distributors,....
Where ya gettin' "Motorcraft" from,..??
What does Merc Manual #1 call yer distributor,..??
ctanke
Hey Bondo,
I'm almost certain the housing was stamped "Motorcraft" because it wasn't what I expected. I'll be working on her this weekend and will check again. Please check back to this post after the weekend when I update. Thanks in advance for your help. chris
Ayuh,.... If it's on page 1, I'll find it,.....
Did ya look in manual #1,..??
Follow the links from Don'S Adults Only section, to the factory manuals,.....
ctanke
Just back from the boat. It is marked "Motocraft" on the distributor housing. Other numbers stamped are 2312, DIJF 12127 MA.
I believe this is the original distributor. Please advise as to electronic ignition conversion, and finding other parts to tune up this old gal
Thanks Chris
mandmj
I'm afraid I cant help much about the question at hand, but I can tell you from my time as a Ford guy that a part number D1JF is a 1971 Ford Part. The first letter is the decade (c=60s, d=70s, e=80s, etc) and the second number is the year of the decade, so D1 = 1971 production.
ctanke
Update guys,
Although uncommon Motorcraft distributors were dropped into some Mercruiser 888s in 1971 and 1972. As noted D1JF stamped stands for D for 70s decade,
1 stands for year, J means it's marine, and F stands for "electronic division". Petronics makes a conversion kit 912884 and marine grade coil 45111 which will work. Thanks for the help! Chris
