electric fuel pump problems
Retsgtmoose
I have a 2007 Mercury 40HP EFI and have problems starting it. I have reduced the problem to the electric fuel pump. I have checked the the fuses for the fuel pump/idle air control/fuel injector circuits and found that there is no power on either side of the 20amp fuse. can anyone tell me where this fuse gets its power. I would like to check that out before I go any further.
alldodge
Not an OB guy, but Merc uses the same wiring colors.
Battery - Red
After main engine breaker - Red/Purple
Red/purple to ignition fuse (normally 20A) to key switch
Key switch to Run circuit - Purple
alldodge
Check kill switch
After the key switch (turns power ON) it goes to the kill switch (man overboard) then to MPR fuse then MPR
Retsgtmoose
Battery - Red
Thank you for your reply. This thing has turned into a Pandoras Box, I fix one thing and another pops up.
Retsgtmoose
Check kill switch
Thanks for your reply. The kill switch was checked and I found it to be working.
alldodge
Where does power stop?
Is it before the key switch, after it, just where?
Retsgtmoose
As near as I can figure it stops at a relay at the rear of the motor. There are three stacked up back there and it appears to be the lower of the three.
alldodge
The MPR should have 12V on one side full time. If it does not, then its a fuse, a bad connection or broken wire.
The relays can be swapped with each other
Retsgtmoose
Thanks I,ll have a look at that! The MPR is the lower relay?
alldodge
Don't know which one is which, but the MPR has to energize to supply power to others. It should be like this, but note this is for a Mercruiser but it should be the same just maybe different pins numbers
Retsgtmoose
Retsgtmoose
cleaned all the contacts and the thing started ( thank goodness) but I now think that I have to replace the water pump impeller. Thanks for all the very good advise that everyone gave me on this problem.
