Serial # 5253426 2 cly. Motor starts and runs good for about 15 minutes and then dies . Will restart in about 20 minutes after it has cooled down. Installed new stator and switch box. Helped some, runs longer, but still dies. Help please !
Laddies said:You need to see if the engine is losing spark or not, I think it probable is, If it is electric start the rectifier could be the problem (don't just change things it don't work ck them) disconnect the 2 yellow wires a the rectifier tape and run the engine, if it don't act up then change the rectifier, if it does ck the trigger wires (brn to white for continuity) if the are open change the trigger. Either part will cause the problem you are experincing
