- Jul 18, 2011
- 19,557
Re: Easy Winterizing
Hi Lou:
I think this is the first time I have 'seen' you over here on iBoats. I am a relative newcomer over here.
I just found the drains on the engine block. I was not sure where they were, but now that I have the engine out of the boat, I found them. Of course they are kind of clogged up, but they opened up without too much effort.
I'm still going with my 'hybrid' approach - run anti-freeze through the outdrive/engine and then drain the block and manifolds. Sort of the best of both worlds.
Yep that 'easy way' will get you a cracked block if the thermo does not open all the way, if you don't want to fiddle with drain plugs, you have 2 choices, get an outboard next time, or an inboard with closed cooling (still have to drain the heat exchanger and raw water lines). Otherwise, do it the right way.
Hi Lou:
