E60tlene stator???
Tcla5988
Just replaced the powerpack. Replaced the ignition switch, and checked the kill circuit. All good!! But I still get no spark to all my cylinders. The boat ran great for two months easy after I restored it from ethanol poisoning. It's getting fuel I know and compression. I want to say Its the stator.. Trigger works smooth and all appears good visually. The only thing is on the inside of a plug to the coil there is a lil corrosion on the stator side orange wire. Could this be my stator being shot?? Seen no plug is firing?
schematic
Re: E60tlene stator???
neither stator nor trigger can be verified visually. You must test them electrically. Go to CDI website and use their troubleshooting section.
