BuncesPassBoater
- Jul 19, 2013
- 10
Greeting Everyone,
I just bought a 1985 Evinrude 140 V4. When I bought the motor it was running great on muffs and thought I purchased a good motor. However, I've had problems with it since I brought it home. I'll spare the details on some of the stupid things I did trying to run/test it and get right to the immediate problem...
I wanted to check the timing and when I tried to confirm TDC on # 1 piston discovered that it is off by about 135 degrees. (pic attached)
What should I do?
I've been soaking flywheel nut with breakfree thinking I'm going to have to pull the flywheel and and just re-install correctly. My question is will that affect the alignment of the flywheel magnets, charge coil, sensor coil and stator assembly? Any advice/input is greatly appreciated.
I've read so much and picked up alot of info already from this forum that has been very helpful. You guys are great and I'm impressed by how much time and effort you put in to help out guys like me. I'm mechanically inclined and pretty intuitive but have just enough experience to make things worse and get my self into trouble. Thanks in advance.
What should I do?
