dumb exhaust question
jimmy wise
I have a 898 set up for my boat and one of the manifolds are missing. should I use the set of aluminum manifolds and risers and run through the transom or look for a newer used set of center rise manifolds. just one of the options I have
alldodge
Re: dumb exhaust question
Hey just went through a lengthy discussion on a very similar item. Here is the link where aChris did a great job with showing the cooling system
http://forums.iboats.com/mercruiser-i-o-inboard-engines-outdrives/overheating-633114-3.html
In the 3rd page you can see the routing. My thought would be to replace both with new style manifolds and elbows then re-run hoses. Would like to see your setup (Pics please) to verify we are discussing a similar issue
achris
More fish than mountain goat
Those drawings are for a Ford engine (888), this OP has a GM (898), although very similar, the thermostat housing hoses are different. Here's a set of drawing I did for someone to convert from the older 'log' style manifolds to the latest 'dry-joint' centre rise manifolds. Although these drawings are labelled '228', the only difference between your 898 and the 228 is a 2 bbl carb vs 4 bbl. http://forums.iboats.com/mercruiser...center-riser-question-602778.html#post4204080
And yes, a set of photos would be very helpful.
Chris......
jimmy wise
ok ill get some picts but snow everywhere ...... the aluminum are like hardin marine wet manifolds and aluminum risers for sbc.
jimmy wise
also I have a closed cooling set up for it....rebuilt motor. should I just get the log manifold and run those?
achris
Personally, I'd go to dry-joint manifolds... For those, and a full closed cooling system, use block-off gaskets between manifold and elbow.
alldodge
Chris......
I'll learn one of these days, nope not really, but I'll will continue to try to give out doey points
