Dual Batteries
novicebaylinerowner
Can you fry your system if you start on all? I can only run my radio on all, can I use all to start and run?
Re: Dual Batteries
If the batteries are connected in parallel, the duial batteries will have 12VDC and look like one large one to the motor, radio etc. If conected in series the voltage will be 24VDC and will burn out 12 volt stuff.
tekmunki
Re: Dual Batteries
AFAIK on an AB switch, or at least on mine, placing A+B connects the batteries in "parallel" and not in "series" which does not double the voltage, but only the amp hours, and from what I know, increases the CCA.
If either A or B on the switch is connected to a "series" of batteries, then I imagine it would be worthy of frying something. My switch instructions specifically state to use A+B in 'emergency' starting situations, I wouldn't worry, but I also wouldn't make a practice of it- can't be great whichever is the weaker battery.
smokeonthewater
Re: Dual Batteries
YES you can start on all..... if it was gonna fry anything it would have fried your stereo.... now the reason for the battery switch is so that you don't get stranded.... you should be running your stereo off ONE of them so that if it runs down you can still switch to the other to start the engine..... If for some reason both batteries are to low to start the engine you should switch to ALL and just HOPE that together they can start the engine.
dirtyoldman
Re: Dual Batteries
if they are in parallel why would the radio only work in ALL?
