novicebaylinerowner
Thread starter- Joined
- Jul 7, 2011
- 1
Can you fry your system if you start on all? I can only run my radio on all, can I use all to start and run?
AFAIK on an AB switch, or at least on mine, placing A+B connects the batteries in "parallel" and not in "series" which does not double the voltage, but only the amp hours, and from what I know, increases the CCA.
If either A or B on the switch is connected to a "series" of batteries, then I imagine it would be worthy of frying something. My switch instructions specifically state to use A+B in 'emergency' starting situations, I wouldn't worry, but I also wouldn't make a practice of it- can't be great whichever is the weaker battery.
if they are in parallel why would the radio only work in ALL?
