Dt65 Crankshaft seals
bigman348
I am wondering if anyone out there has replaced crank seals on an 87 dt65? I am looking to replace the upper and lower seals and don't know if I have to crack the case to do it. I have a manual but it doesn't specify if the case needs to be split.
Thanks for any and all help!
stylesabu
Master Chief Petty Officer
Re: Dt65 Crankshaft seals
are they leaking? I have a used dt75 out in the shed I'll ,ook tomorrow to see if the seals and be removed without splitting case.
bigman348
It seems to be all that is left for me at this point. I have tested and replaced everything that I can replace and still have a no power under load condition. And the process of checking them for leaks isn't easy or cut and dry. Thanks for looking for me I really appreciate it.
Thanks,
Matt
