Tanksmydog
Thread starter- Joined
- Jul 8, 2008
- 41
I need to know how to install the cable and tension springs on a Exposed Drum Steering setup. If possible I need pics or diagrams...Please help.
no you never cut the cable, until finished. you start at the drum, thead the cable thru the drum, till you get 1/2 way, now you wrap the drum, the way the directions tell you, then use the duct tape to hold cable on drum. now take the appropriate end of the cable and feed it thur the pulleys, back to the motor, follow arrows or diagram. once you have finished and tested the system, cut the ends of the cable about 3 inches past the clamps.
